| KaptKaos |
May 20 2005, 05:36 PM
Family ![]() ![]() ![]() ![]() Group: Members Posts: 4,009 Joined: 23-April 03 From: Near Wausau Member No.: 607 Region Association: Upper MidWest |
I took my 914 to a reputable shop here locally to have some work done. It was running roughly and I didn't have time to monkey with it myself.
Anyway, while there and on a test drive with me in the car, the brake pedal went straight to the floor. I had previously always had firm brakes, good pads, and no other braking problems. We get back to the shop and look at the pedals and there is fluid everywhere. Ok, master is shot. Ok to replace it with a new 19mm master. Call the shop a few days after parts arrive, new master is in, but the pedal is still mushy. Shop owner asks me if I want to replace the brake lines. I didn't really, but I had a set braided lines, so I drop them off. Still no improvement. Owner suggests to remove the proportioning valve and replace it with a T-connector. T - connector is a $15 part, he does it all the time - fine, go ahead. A couple days go by (been really busy at work) and I stop by this AM and the brakes are still really mushy and go all the way to the floor. Pumping them up brings the pressure back but its still a problem. I call this afternoon and speak with the owner. He tells me that they found a leak in a hard line that runs from the pedal cluster back towards the firewall. I am going to go look at it tomorrow first hand. How we fix that line and how it broke are still open issues as well. So it looks like it may not have been the brake master or the proportioning valve and definetly not the brake lines. I take the car to this person because he has a good reputation, has been very fair with me in the past and for his expertise in solving these problems. Given what we have found - what is reasonable to expect in terms of the labor charges? Any guidelines here would be greatly appreciated. Thanks! |
| ArtechnikA |
May 21 2005, 06:42 AM
rich herzog ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,390 Joined: 4-April 03 From: Salted Roads, PA Member No.: 513 Region Association: None |
that 'Z' -shaped line that runs from the input to the proportioning valve, up through the gap in the firewalls and into the tunnel is a b!tch to replace - you have to get the bends exactly right and then snake it up into a place you can't see at all. "replace hard line" sounds like it could be a 10-minute job but i recall it taking me about 3 evenings the first time i did it. i even ordered the 'correct' part from the dealer hoping it'd come with the right bends, but it didn't - it was just the 'right' length. if i'd been smart, i'd have pulled it back out when i got it right and traced a template but i was so relieved to have it done i connected the fittings and moved on. |
KaptKaos ** Need some help ** May 20 2005, 05:36 PM
914Sixer Well, you now have some nice upgrades. In the 20 ... May 20 2005, 05:48 PM
KaptKaos ... May 20 2005, 05:54 PM
SirAndy ... May 20 2005, 05:56 PM
LukeD I had some what of a similar experience. Reputable... May 20 2005, 05:59 PM
ArtechnikA at some point "the guy" decided to delegate stuff ... May 20 2005, 06:20 PM
BMartin914 I too have had a similar experience. Couldn't ... May 20 2005, 06:33 PM
Headrage What I have seen time and again is if you take a c... May 20 2005, 06:48 PM
scruz914 I am going to guess that the brake system, althoug... May 20 2005, 07:03 PM
mikester Yeah, that's a good question - what's the ... May 20 2005, 07:30 PM
firstknight13 BE THANKFULL that you were not in trafic or racing... May 20 2005, 07:38 PM
Eric_Shea ![]() ![]() |
Lo-Fi Version | Time is now: 4th March 2026 - 09:59 PM |
