> push rod seals, do I use permatex?
joeav8tor
post Mar 29 2005, 08:23 PM
hi guys,
I have dropped my engine to do some preventative maintenance...I am going to install some push rod tube seals...do I use permatex on them...also got some valve cover gaskets...do I use it on them?
thanks (IMG:http://www.914world.com/bbs2/html/emoticons/ar15.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/beer3.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/ar15.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/idea.gif)
Joe
Cap'n Krusty
post May 21 2005, 04:41 PM
Cap'n Krusty
Jake and I disagree here. Pretty rare when we do, but this is one of those times. I've been oiling them for 32 years now, and I find it workds just fine. I use the viton seals, clean everything really well, twist the tubes while installing, and never have leaks. I glue the VC gaskets to the valve covers with an old time product called "Gasgacinch". Find it in better REAL autoparts stores. You shouldn't be in those other ones anyway. Apply the sealant to the valve cover and the CORRECT side of the gasket, let'em air dry while you adjust the valves, then carefully put them together. Works great! Being able to pull them apart with relative ease is a bonus. The Cap'n
joeav8tor   push rod seals   Mar 29 2005, 08:23 PM
scotty b   vaseline or anti seaze on the push rod seals. NEVE...   Mar 29 2005, 08:32 PM
Jake Raby     Mar 29 2005, 08:53 PM
scotty b   I will bow to YOUR knowledge. ...   Mar 29 2005, 09:15 PM
Jake Raby   Loctite 565. Its available at my store. It's ...   Mar 29 2005, 09:24 PM
beemie96   Is there a particular kind of Permatex to use? Or...   May 21 2005, 04:33 PM
- Lo-Fi Version Time is now: 9th June 2026 - 07:12 PM
