| Rhodes71/914 |
May 21 2005, 09:38 PM
Glacier ![]() ![]() ![]() Group: Members Posts: 1,374 Joined: 8-August 04 From: End of the Road, Alaska Member No.: 2,482 |
Engine is a 2L Type IV with FI.
Car was just trailered 3000 miles and wouldn't start. Points had gone bad, put new points in and car ran great. Made a 250 mile drive with no problem. Driving around town it started hesitating and bucking around 3000 rpms but would rev past that and be fine. steadily got worse. Now it will fire up, run for a few seconds and die. Fuel pressure is good, put another set of points in, checked and cleaned the trigger points. Contacts in the dizzy cap had some discoloration so I cleaned that off. It seems like an ignition problem. Haven't replaced the condensor, how do you know if that is bad, I have read they don't go bad often. Seems like it wouldn't start at all if it was bad. Give me any suggestions, I'm stuck. |
| Rhodes71/914 |
May 21 2005, 11:54 PM
Well now I need to find a fuel filter that will work from NAPA, until I can get the right one.
I did syphon the gas out of the tank in the Yukon when the Uhaul ran out, then I tried to run it on an empty tank, maybe I got some nasty stuff in there. Fuel was what I first thought the problem was but since the pressure was good I moved on. How about the pump? Can it partially work and just not pump enough? Sounds like it always has. I miss my garage, all my spare stuff is in boxes in a storage unit. (IMG:http://www.914world.com/bbs2/html/emoticons/mad.gif) Oh well, I did catch a Halibut the other day. |
Rhodes71/914 Engine Starts, Won't Run May 21 2005, 09:38 PM
dlo914 check for spark on a 4 plugs, and see if the ignit... May 21 2005, 09:47 PM
! Spark, Fuel, Air
Even though the pressure is fine... May 21 2005, 10:02 PM
boxstr I worked on a car for a day and finally found the ... May 21 2005, 10:09 PM
bd1308 replace the condensor...i started frying points li... May 21 2005, 11:19 PM
Rand ![]() ![]() |
Lo-Fi Version | Time is now: 9th November 2026 - 12:16 PM |
