| Mueller |
May 21 2005, 11:56 PM
914 Freak! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 17,155 Joined: 4-January 03 From: Antioch, CA Member No.: 87 Region Association: None
I was testing the wiring for my Link ECU using the dizzy and my Mallory CDI box......I cannot get spark using the ignition trigger from the Link...my output is normally 0vdc and goes to ~10vdc when the window appears on the dizzy....
If I bypass the Link ECU and wire the Mallory CDI box directly to the dizzy (Mallory Unilite) I get spark...it's normally 0vdc and goes to 5vdc with window open. Link has never done a Mallory install and usually uses the MSD box, they do mention that the MSD box needs to have a resistor changed internally to go from what I thought they said low level to high level. it seems that if I can get my Mallory CDI box to output 5vdc instead of 10vdc it might work..... oh yea...the "white" wire on my Mallory reads approx 10 to 11vdc thanks |
| Mueller |
May 22 2005, 12:12 AM
believe it or not, I did a google and found it....
MSD reverse engineered (pdf) 350mA @ 14vdc still not sure what the mod was....might have to wait until Monday (IMG:http://www.914world.com/bbs2/html/emoticons/sad.gif) |
Mueller Need voltage for MSD CDI box....for Link install.. May 21 2005, 11:56 PM
lapuwali The Link won't do wasted spark?
Have you gott... May 22 2005, 01:13 AM
Mueller I could do fuel only, it's not too hard to unl... May 22 2005, 01:29 AM![]() ![]() |
Lo-Fi Version | Time is now: 19th March 2026 - 01:45 AM |
