| xsboost90 |
May 22 2005, 01:35 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,393 Joined: 2-August 04 From: cincinnati Member No.: 2,432 |
so im impressed that my new motor starts right up and runs. I put my hand in front of the exhaust to see what the temperature of the exhaust was to see- kinda- running rich/lean or what. I notice that #2 cylinder has no exhaust coming out. I check the plug, drowned. Well, my new plugs were stock plugs, so i switch them all out to the hotter plugs that came in the motor, #2 is drowned immediatly. I check spark, perfect. I check injector pulse, perfect. I did an experiment. I took the injector out, put in a new plug that was perfectly clean- drowned it after a brief start. Ok so where is this "gas" or liquid coming from. Im thinking the case is full of gas. Im scared to check the crankcase though. I have a ghetto compression tester, you push it in and hold it while someone cranks. #1 has like 110lbs roughly, #2 has 60-70lbs, 90lbs if you hold it there a couple seconds. IF my crankcase is full of gas-from cranking and cranking w/o ignition the last couple of days- and i drain it, any chance my compression will come back up and itll stop drowing plugs or do i need to take it back out and rebuild it already????? (IMG:http://www.914world.com/bbs2/html/emoticons/sad.gif)
| Allan |
May 22 2005, 08:57 PM
Teenerless Weenie ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,373 Joined: 5-July 04 From: Western Mesopotamia Member No.: 2,304 Region Association: Southern California |
(IMG:http://www.914world.com/bbs2/html/emoticons/smilie_pokal.gif) Way to go.... Now move on to the next issue and beat it!!! We WILL meet up at the WCC '06!!!!!
Keep the faith. |
xsboost90 Is my new engine screwed? May 22 2005, 01:35 PM
! Do the dance....check valve clearance, do a compre... May 22 2005, 01:39 PM
Lawrence You may have two problems. Start with the mechani... May 22 2005, 01:40 PM
Headrage If you can, just take a quick look down the thrott... May 22 2005, 01:46 PM
Aaron Cox lots of gas in the cylinders means bad things on n... May 22 2005, 01:47 PM
xsboost90 well, the engine was built and the guy ran it for ... May 22 2005, 03:19 PM
xsboost90 ok, so while checking to make sure the valve adjus... May 22 2005, 08:54 PM
! Change the oil and look to see if there is any gas... May 22 2005, 09:00 PM![]() ![]() |
Lo-Fi Version | Time is now: 12th July 2026 - 03:28 PM |
