Grind Me A Pound, First , Second and Reverse gears grind |
dralf |
May 23 2005, 07:09 PM
Member Group: Members Posts: 230 Joined: 24-January 04 From: Dayton, Oh Member No.: 1,597 |
Been Driving my teener for a week and I think I am slowely destroying my transmision. I had to replace the shift linkage bearings last fall and adjusted the clutch, and for the few test spins I took it seemed OK. But now that I drive it a bit, it seems to grind when I am in neutral and want to put it into reverse ( yes I am depressing the clutch ). At a stop as I shift into first it somethimes grinds and unless I accelerate and shift real slow it grinds going into second.
I just adjusted the clutch cable tonight and tightened it a bit more but that may have made it a bit worse. One final observation, This is a side shifter 2 L 1975, and boy it seems that second and fourth gears are close together. Is it time to consider a trany rebuild ? Is it the clutch ? Is it the linkage requiring more fiddling (IMG:http://www.914world.com/bbs2/html/emoticons/sad.gif) I am excited to drive the baby but I don't want to dammage something, any sugestions will be appreciated. Signed, Shiftless in Ohio |
Red-Beard |
May 24 2005, 06:35 AM
"Ya canna change the laws of Physics" Group: Benefactors Posts: 1,124 Joined: 11-February 03 From: Houston, TX Member No.: 288 Region Association: None |
Use a dab of loctite on the screw...
If it is grinding in gears and in reverse, mostly likely the clutch is dragging (adjust the cable) or the pilot bearing is dragging. If you can adjust the problem away with the clutch adjustment, and it comes back in a week or so, immediatly order a new clutch cable, as yours is about to break. |
Lo-Fi Version | Time is now: 6th June 2024 - 08:32 PM |
