90o AN fitting to the stock cooler?, for the /6 conversion... |
DougC |
May 25 2005, 01:53 PM
Senior Member Group: Members Posts: 949 Joined: 6-July 04 From: Dallas, TX Member No.: 2,307 |
I have AN hose that I'll be running from the 914/6 oil tank to the (engine mounted) oil cooler. I know that the cooler has to be modified but since I have a simple weld-on straight AN adapter, couldn't I just weld that adapter onto the blank end of the cooler's pipe then use a 90 degree AN fitting to attach it to the hose? I mean is there enough room to do that? Would the cooler's pipe (which has no threads) have to be shortened, by how much? Would a 45 degree fitting work..I already have one of those? I haven't seen anyone do it this way, only seen 90 degree fittings welded to the cooler's pipe..any pics?
Doug C |
michel richard |
May 25 2005, 02:00 PM
Senior Member Group: Members Posts: 1,291 Joined: 22-July 03 From: Longueuil, Québec Member No.: 936 |
Not sure exactly what you mean, but there is very very little room outside the oil cooler, maybe less than an inch. That's why you really have to make that connection inboard of the cooler edge.
Michel Richard 914/6 2.2E MFI |
Lo-Fi Version | Time is now: 10th June 2024 - 05:09 PM |
