90o AN fitting to the stock cooler?, for the /6 conversion... |
DougC |
May 25 2005, 01:53 PM
Senior Member Group: Members Posts: 949 Joined: 6-July 04 From: Dallas, TX Member No.: 2,307 |
I have AN hose that I'll be running from the 914/6 oil tank to the (engine mounted) oil cooler. I know that the cooler has to be modified but since I have a simple weld-on straight AN adapter, couldn't I just weld that adapter onto the blank end of the cooler's pipe then use a 90 degree AN fitting to attach it to the hose? I mean is there enough room to do that? Would the cooler's pipe (which has no threads) have to be shortened, by how much? Would a 45 degree fitting work..I already have one of those? I haven't seen anyone do it this way, only seen 90 degree fittings welded to the cooler's pipe..any pics?
Doug C |
DougC |
May 25 2005, 02:25 PM
OK that confirms I'll have to cut/shorten the cooler's pipe, but there's no other reason an AN 90 or 45 degree fitting couldn't be attached to it via an adapter? Cooler/ weld on straight AN adapter / 45or90 degree AN fitting / AN hose / Tank.. that's the plan I guess.
Doug C |
Lo-Fi Version | Time is now: 11th June 2024 - 03:59 AM |
