MPS Certificate, slow leak ?? |
MarkV |
Jul 9 2003, 08:42 PM
Fear the Jack Stands Group: Members Posts: 1,493 Joined: 15-January 03 From: Sunny Tucson, AZ Member No.: 154 Region Association: None |
I just got my wiring harness & MPS back from Jeff Bowlsby. Jeff tested my MPS & made some repairs to my harness. Jeff did a great job on the harness. (IMG:style_emoticons/default/pray.gif)
The MPS passed all of the tests except for the leak down test. The standard leak down is from 40 cm/Hg in 4 minutes, mine leaked down in less than 2 minutes. I was wondering if I should take it apart to try to fix the leak, or just run it. It's a sealed MPS that appears to be a rebuild. (IMG:style_emoticons/default/confused24.gif) Attached thumbnail(s) |
Lawrence |
Jul 10 2003, 04:01 PM
Senior Member Group: Benefactors Posts: 1,661 Joined: 5-February 03 Member No.: 244 Region Association: None |
QUOTE Ok, I give away the secret settings here For a 2056cc you need at 0hg (WOT) about 1.50 -1.55 At 4hg (partload ) you need 1.26-1.28 At 15hg (idle) you need .74-.77 This gives you the proper A/F mix at partload about 13.7 to 1 and at WOT about 12.5 to 1 Write it down cuz this message will self destruct in 12hrs. Geoff Saved for posterity. (IMG:style_emoticons/default/smile.gif) |
Lo-Fi Version | Time is now: 23rd May 2024 - 04:11 AM |
