> Jack placement for lowering engine/tranny, Should be a quick answer!
Air_Cooled_Nut
post Jun 1 2005, 03:54 PM
914 Ronin - 914 owner who lost his 914club.com
I'm ready to lower the engine/tranny from my 914. I've decided NOT to do the Pelican method. On my Type 3 I've lowered the engine as well as the engine and tranny using a small floor jack -- it was quite the balancing act but I've done it multiple times. I now have a standard sized floor jack (bigger saddle that is removeable) and will be using that for the drop.
The Question:
Where should I place the saddle for lowering the engine with the transaxle?
My guess would be between the engine/tranny mating and the "taco plate" (is that the right term?). I have bits of wood and scrap metal so I could either weld a custom saddle for this drop or just use some plywood between the saddle and engine/tranny. Recommendations and experiences? TIA! (IMG:http://www.914world.com/bbs2/html/emoticons/beerchug.gif)
Joe Bob
post Jun 1 2005, 04:55 PM
No...but disconnect the battery, remember the ground strap on the trans, the heater cables, the throttle cable, clutch cable etc....
The fuel lines are best crimped with needle nosed vice grips AND to have a bolt shoved into the end...
- Lo-Fi Version Time is now: 7th July 2025 - 11:52 AM
