Just ordered an Accusump.... |
Joe Bob |
Jul 13 2003, 09:53 AM
Retired admin, banned a few times Group: Members Posts: 17,427 Joined: 24-December 02 From: Boulder CO Member No.: 5 Region Association: None |
The T-4 motor in my 356 has decent head temps
but the oil temp gets high after about 20 minutes. I am running a stock oil cooler and electric fans w/o a crank run fan....custom sheet metal due to a T-4 never being designed for a 356 tail dragger. So.....I ordered a sandwich plate, diverter, Mocal oil cooler, a $hitpot of braided lines, and an Accusump. For those not familiar with an Accusump, it is a 3 quart capacity pre oiler system. You hit a switch prior to engine ignition and it pressurizes the oil system up to optimum operating parameters. THEN you fire the motor up. It adds three extra quarts of oil, allows the engine to start with full oil pressure and helps with extra cooling. It also has a check valve that pressurizes ONLY the engine side. Then the thermostat opens at temp and allows warm oil to the cooler...... |
ChrisReale |
Jul 13 2003, 12:42 PM
Sleazy Group: Members Posts: 2,665 Joined: 20-January 03 From: San Francisco Member No.: 176 |
What size oil cooler did you get? Where dod you get it from?
Lo-Fi Version | Time is now: 15th June 2024 - 03:05 PM |
