> More V8 conversion questions..., ...the rebuild continues
neo914-6
post Jun 5 2005, 04:09 PM
neo life
A few questions:
1) Harmonic Balancer bolt spacer: Is this supposed to fit "in" the hole (there's a countersink)? If I used the bolt that came as a set, it would be too long. Plus the head was long. Those two stacked stick out the front of the car ~ .635". I know there is little space between the firewall and the front of the engine. It should be fine if it is positioned above the shelf where there is more space in the center but I think it is below.
neo914-6
post Jun 5 2005, 04:24 PM
neo life
5) How do you deal with this kink? Wind it tight so it has a curved memory, clamp or wrap the hose at the kink, add an elbow, not worried about it as it will fill out with pressure?
- Lo-Fi Version Time is now: 16th November 2026 - 03:25 AM
