> Lower my fuel pressure to help w/fuel injectors.., ...being too large???
Mueller
post Jun 12 2005, 08:54 PM
914 Freak!
Running 2.0 injectors on my stock 1.8, new fuel injection fires all 4 at one time (batch), I have a feeling new injectors are too much....anyone lower their fuel pressure to compensate for large injectors??
I'm wondering how low can I go yet still retain a nice reliable pattern?????
snflupigus
post Jun 13 2005, 06:22 PM
GM tbi injectors often go "static" - meaning they stay constant open because by the time they might close they are opening again because the fuel needs still havent been met... we've had a lot of problems making power with the system. They go static pretty quick because they are such large injectors and they take so long to open and close. We've used vacuum adjustable regulators so that fuel pressure is low at high vac and high at no vac. The pressure has to be increased at WOT and pulse width messed with a TON so as to still correctly meter fuel down at low rpm, while at WOT they can go static and be in full open but still delivering the right a/f ratio for peak power.
Mind you these small block chevy engines are running about 350hp+ with only 2X80lb/hr injectors at twice the rated fuel pressure.
I thought you guys were referring to tuning the stock djet system. I was getting excited for a moment thinking that my old prom burner might come into use again LOL
Mueller   Lower my fuel pressure to help w/fuel injectors..   Jun 12 2005, 08:54 PM
TimT   if I remember Link 1 you can fire injectors 180 ap...   Jun 12 2005, 09:10 PM
TimT   Also keep your fuel pressure constant... thsi e...   Jun 12 2005, 09:11 PM
snflupigus   is there a removable programable chip in these ecm...   Jun 13 2005, 01:05 AM
0396   Running 2.0 injectors on my stock 1.8, Interestin...   Jun 13 2005, 07:35 AM
DNHunt   Mike I know you can lower them a little but, I se...   Jun 13 2005, 07:47 AM
airsix   Mike, What pressure are you running? Have you modi...   Jun 13 2005, 08:55 AM
Mark Henry   I'm running 2.0 injectors on my stock 1.8 righ...   Jun 13 2005, 09:00 AM
Mueller     Jun 13 2005, 12:01 PM
lapuwali   You have to be careful on open/close times. The n...   Jun 13 2005, 12:32 PM
airsix   ...   Jun 14 2005, 10:45 AM
Dave_Darling   Mike, I recall reading on the Rennlist a year or s...   Jun 14 2005, 11:00 AM
airsix
- Lo-Fi Version Time is now: 7th August 2026 - 04:31 PM
