> 2 questions
ruddyboys
post Jun 14 2005, 06:23 AM
Hummel eigentümer
Trying to set the timing. I cant get the car to run smooth. I watch the timing mark dancing around. it moves back and forth about 3/4 inch. Also I my idle speed is F*&%ed up. I have the idle speed set to about 1800rpm, when I move the car the idle speed goes way way up (throtle cable not stuck). If I turn the car off and then start again the idle speed goes to around 1800.
solex
post Jun 14 2005, 07:57 AM
QUOTE (xsboost90 @ Jun 14 2005, 04:45 AM)
according to the manual, the timing should be set while running the motor at 3500rpm at 27degrees, there is a mark on the flywheel that will line up w/ the notch in the inspection hole.
Just a quick update the timing should be set to 27 BTDC at 3500. I recently tried this but cannot find the mark on the fan wheel...
- Lo-Fi Version Time is now: 1st July 2025 - 03:06 PM
