| VegasRacer |
Jun 15 2005, 10:32 AM
ELVIRA ![]() ![]() ![]() ![]() ![]() Group: Benefactors Posts: 8,933 Joined: 27-March 03 From: Between Scylla and Charybdis Member No.: 481 Region Association: None
Let's see how good you guys really are.
The passenger seat in Elvira has never moved as long as I have had the car. I figure now is about time to fix that. At first I thought it might be bolted in. That is not the case. The seat is all the way back. It is some how hung up past the last stop on the slider. The tilt lever does move, but there is no where for the seat to go. The seat is wedged in as far back as it can go. I have pulled as hard as I can but the seat will not move forward. Where is it caught and how do I get it un-stuck? No, a (IMG:http://www.914world.com/bbs2/html/emoticons/sawzall-smiley.gif) is not an option. |
| scotty914 |
Jun 15 2005, 10:35 AM
suby torque rules ![]() ![]() ![]() Group: Members Posts: 1,528 Joined: 20-July 03 From: maryland, the land of 25 year Member No.: 924 |
could the bar that connectes both sides be broken and therefore only lifting on one side.
try sticking a long long screw driver or a piece of metal in to lift the other side and then try to slide it edit: you are moving the seat tilt or trying to slide the seat you said the the tilt lever moves but the seat might be tilted all the way forward and cant go back because the seat is slid back. the slide lever is on the front of the seat, the tilt is on the side pull the drivers seat if it is still on the stock slider pull it out to see how it works This post has been edited by scott thacher: Jun 15 2005, 10:42 AM |
VegasRacer Need Help - How to move a stuck seat Jun 15 2005, 10:32 AM
VegasRacer I mentioned the tilt lever just so you would know ... Jun 15 2005, 10:53 AM
! Depending on where the seat is stuck at....most of... Jun 15 2005, 11:01 AM
ArtechnikA check for stuff (pencils, dimes, hairpins...) stuc... Jun 15 2005, 11:03 AM
VegasRacer Problem solved. Thanks for the support guys.
Here... Jun 15 2005, 11:08 AM
! Didya find the crack pipe? Jun 15 2005, 11:09 AM
VegasRacer ![]() ![]() |
Lo-Fi Version | Time is now: 16th April 2026 - 04:42 AM |
