> Need Help - How to move a stuck seat, Anybody go any tricks up their sleeve?
VegasRacer
post Jun 15 2005, 10:32 AM
ELVIRA
Let's see how good you guys really are.
The passenger seat in Elvira has never moved as long as I have had the car. I figure now is about time to fix that. At first I thought it might be bolted in. That is not the case. The seat is all the way back. It is some how hung up past the last stop on the slider. The tilt lever does move, but there is no where for the seat to go. The seat is wedged in as far back as it can go.
I have pulled as hard as I can but the seat will not move forward.
Where is it caught and how do I get it un-stuck?
No, a (IMG:http://www.914world.com/bbs2/html/emoticons/sawzall-smiley.gif) is not an option.
VegasRacer
post Jun 15 2005, 11:08 AM
ELVIRA
Problem solved. Thanks for the support guys.
Here is the offending object. Another DAPO problem.
VegasRacer   Need Help - How to move a stuck seat   Jun 15 2005, 10:32 AM
scott thacher   could the bar that connectes both sides be broken ...   Jun 15 2005, 10:35 AM
VegasRacer   I mentioned the tilt lever just so you would know ...   Jun 15 2005, 10:53 AM
!   Depending on where the seat is stuck at....most of...   Jun 15 2005, 11:01 AM
ArtechnikA   check for stuff (pencils, dimes, hairpins...) stuc...   Jun 15 2005, 11:03 AM
VegasRacer   Problem solved. Thanks for the support guys. Here...   Jun 15 2005, 11:08 AM
!   Didya find the crack pipe?   Jun 15 2005, 11:09 AM
VegasRacer
- Lo-Fi Version Time is now: 16th April 2026 - 04:50 AM
