| DNHunt |
Jun 17 2005, 06:28 PM
914 Wizard? No way. I got too much to learn. ![]() ![]() ![]() ![]() Group: Members Posts: 4,099 Joined: 21-April 03 From: Gig Harbor, WA Member No.: 598 |
Wednesday afternoon I couldn't stand it any longer. Teachuing my son to drive a stick has taken it's toll on an already bad situation. So, I got new dogteeth and syncro from Rich and had at it. The hardest prt was getting the dog teeth out of 1st gear. I finally just used a sharp chisel and tapped them off. Left the tranny and engine in the car and just lowered it enough for access.
| Red-Beard |
Jun 18 2005, 02:16 PM
"Ya canna change the laws of Physics" ![]() ![]() ![]() Group: Benefactors Posts: 1,124 Joined: 11-February 03 From: Houston, TX Member No.: 288 Region Association: None |
Oh, and to help re-install the cover, "glue" the washer that sits under reverse to the intermediate plate with thick grease. Then, use grease to hold all of reverse together. It will go back together easier if you remove the speed drive from the rear cover then re-install afterwards.
Do not over torque the screw which hold in the speedo drive. 3 ft lbs. Three foot pounds!!!!! |
DNHunt That grinding's gotta go Jun 17 2005, 06:28 PM
DNHunt 1st gear assembly Jun 17 2005, 06:30 PM
DNHunt cover with reverse and speedo drive Jun 17 2005, 06:31 PM
DNHunt Worn dogteeth Jun 17 2005, 06:32 PM
DNHunt Worn slider. The teeth are slightly rounded and th... Jun 17 2005, 06:34 PM
DNHunt The syncro was worn. All in all it was a nice afte... Jun 17 2005, 06:36 PM
xsboost90 hmm... http://www.914world.com/... Jun 17 2005, 06:40 PM
jr91472 have you priced 1st gear sliders?.......... holy... Jun 17 2005, 07:05 PM
Red-Beard The slider in the picture is in pretty good shape.... Jun 18 2005, 08:23 AM
Red-Beard New 1st/reverse slider $395.33
http://parts.... Jun 18 2005, 08:51 AM
DNHunt James
I''m not sure I get how I changed t... Jun 18 2005, 09:22 AM
Red-Beard The alignment is not in/out, but radial.
With the... Jun 18 2005, 01:51 PM
Bleyseng http://www.914world.com/bbs2/h... Jun 18 2005, 01:53 PM
Cap'n Krusty I just VERY ACCURATELY mark the rail and fork. Wo... Jun 18 2005, 03:35 PM
Red-Beard You're right. But you have to mark it _before_... Jun 18 2005, 08:01 PM
DNHunt Ok now I get it.
I assumed that the slot in the s... Jun 19 2005, 09:13 AM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 12:32 PM |
