> getting real old, I thought I would be finished by now....
bd1308
post Jun 19 2005, 12:33 PM
Sir Post-a-lot
so anyway i'm bolting the exhaust up and i notice that the studs are broken on one cylinder....so i need to replace the studs.....
dad got the MAPP torch out ( woah) and i told him too hot.
went and bought a propane torch, heated the head up till the flame went out (gust of air) so around 5 minutes for both studs...they wont budge
is it kosher to buy a (x)MM drill bit, chop off the stud to level and drill and tap out to (x+1)mm?
post Jun 19 2005, 03:09 PM
Resident German
QUOTE (bd1308 @ Jun 19 2005, 01:09 PM)
yup....i'm heating the surround. You're correct....heating the steel stud will make things tighter instead of the desired effect....
i'm sure you already know that but sometimes it's easier to brake them lose if you try to tighten it just a bit first, then try to back it out ...
(IMG:http://www.914world.com/bbs2/html/emoticons/wink.gif) Andy
bd1308   getting real old   Jun 19 2005, 12:33 PM
bd1308   i really need your help here......   Jun 19 2005, 12:34 PM
!   Best to get it out with heat....use the MAPP gas, ...   Jun 19 2005, 12:37 PM
bd1308   white flame, not blue right???   Jun 19 2005, 12:57 PM
Dr. Roger   I just lived through removing a twisted off a cran...   Jun 19 2005, 01:26 PM
Dr. Roger   Oh, and you are heating the surrounding aluminum a...   Jun 19 2005, 01:29 PM
bd1308   yup....i'm heating the surround. You're co...   Jun 19 2005, 02:09 PM
Aaron Cox   done yet? vice grips/oven mit/torch do it. use t...   Jun 19 2005, 02:20 PM
SirAndy     Jun 19 2005, 03:09 PM
bd1308   i'm stressed. tried MAPP, propane, oven mitt, ...   Jun 19 2005, 08:20 PM
redshift   Stay with it Britt! You aren't that far fr...   Jun 19 2005, 08:40 PM
RAR   Another thread just suggested melting paraffin int...   Jun 19 2005, 08:45 PM
Aaron Cox     Jun 19 2005, 10:58 PM
redshift   surface tension.. it works.. Slight void between ...   Jun 19 2005, 11:05 PM
bd1308   ...   Jun 20 2005, 01:23 PM
bd1308   looks good. okay here's what i need help with:...   Jun 20 2005, 01:57 PM
David_S
- Lo-Fi Version Time is now: 4th September 2025 - 06:16 PM
