ruddyboys |
Hummel eigentümer ![]() ![]() ![]() Group: Members Posts: 595 Joined: 3-March 04 From: Monroe, NY Member No.: 1,749 Region Association: North East States ![]() |
Reading an article on the bird board it says timing for a carbed engine should be 34 degrees @ 3200RPM? Is this right or should I stay with 27 degrees @3500RPM.
Mueller |
914 Freak! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 17,155 Joined: 4-January 03 From: Antioch, CA Member No.: 87 Region Association: None ![]() ![]() |
you are correct in the "advance curve" might be less...
see these 2 examples: if you set the dizzy to have 10° at idle and it swings 17° you have a total of 27° now if you set it at 17° idle, you could get a max advance of 34°...the car will be harder to start at 17° static timing |
Lo-Fi Version | Time is now: 19th July 2025 - 04:36 PM |
