> How To:converting rear shocks to adjust. coilovers, Boge shocks with stock dia springs
Mueller
post Jun 20 2005, 11:50 AM
914 Freak!
I decided to add threaded collars to my Boge rear shocks so that I could adjust the ride height (rear too high)
Normally, one buys Koni Yellows or Bilstiens and simply just slides the threaded collar w/adjusting nut over the shock and uses 2.5" diameter springs.
Due to budget constraints, I opted to keep my Welt. 140 springs (would work with stock springs) and my Boge shocks which seem to function just fine.
First step is to take the springs off, then the perch...on the Boges, the perch is held onto the shock by means of 3 formed protrusions on the shock body, I was able to just hit the perch with shock upside down to remove the perch.
I then cut the perch to fit both the adjusting nut and the inside of the collar. After the modifications, the perch is now 2 pieces instead of 1.
In order to get the smaller ID perch over the 3 protrusions, I cut a slot in it to be able to spread it apart so that I could move it lower on the shock body, I also made 3 holes in it for rosette welds to the shock.
The pictures should be pretty self explanatory of before, during and after.
I can now easily adjust the ride height....total cost was about $60 including shipping for the collars and adjusting nut.
maf914
post Jun 20 2005, 02:33 PM
Not a Guru!
Not bad, Mike. (IMG:http://www.914world.com/bbs2/html/emoticons/smilie_pokal.gif)
But someone has to ask, so...Will welding the shock body void the Koni warranty? (IMG:http://www.914world.com/bbs2/html/emoticons/laugh.gif)
Mueller   How To:converting rear shocks to adjust. coilovers   Jun 20 2005, 11:50 AM
Mueller   .....   Jun 20 2005, 11:51 AM
Mueller   ......   Jun 20 2005, 11:51 AM
Mueller   here you can see the lip to hold the collar:   Jun 20 2005, 11:53 AM
Mueller   finished shock, all painted and ready to install.   Jun 20 2005, 11:53 AM
SteveSr   That's really cool Mike,but what happens to th...   Jun 20 2005, 02:01 PM
Mueller   <...   Jun 20 2005, 02:05 PM
andys   Mike, Very ingeneous! Yeah, I too would'v...   Jun 20 2005, 02:18 PM
Mueller     Jun 20 2005, 02:26 PM
maf914   Not bad, Mike. http://www.9...   Jun 20 2005, 02:33 PM
Dr. Roger   Mike, You know i've got the MIG and stick wel...   Jun 20 2005, 02:35 PM
Mueller     Jun 21 2005, 07:39 PM
TimT   koni calls it a spring perch, Im sure the good ol...   Jun 21 2005, 07:43 PM
Travis Neff   Damn, $25 for the set? The coilover kits tha...   Jun 21 2005, 07:46 PM
Mueller   <...   Jun 22 2005, 10:56 AM
914efi   I did a similar thing many years ago on my -6 with...   Jun 22 2005, 10:56 AM
redshift   http://www.914world.com/bbs...   Jun 22 2005, 10:56 AM
SteveSr   Sorry................... http://www...   Jun 22 2005, 11:01 AM
Mueller   ...   Jun 22 2005, 11:54 AM
Mueller     Jun 26 2005, 09:38 AM
Korijo   i measured 53mm, 2.086614". talk about "a gnatt...   Jun 26 2005, 02:43 PM
Mueller     Jun 26 2005, 02:48 PM
Korijo   pretty sure they're 2.5's   Jul 11 2005, 02:38 PM
Porcharu   As an alternitive to welding you can use a "shaft ...   Jan 6 2006, 02:40 PM
r_towle   <...   Jan 6 2006, 02:48 PM
- Lo-Fi Version Time is now: 5th November 2026 - 05:27 PM
