Roger's 914 thread., I could have had a V8! |
Dr. Roger |
Jun 16 2005, 12:44 AM
A bat out of hell. Group: Members Posts: 3,944 Joined: 31-January 05 From: Hercules, California Member No.: 3,533 Region Association: Northern California |
In summary:
Found the car on Craigslist. Low mile, low rust, straight body. No holes in the hell hole. Longs are clean. A small miracle. (IMG:http://www.914world.com/bbs2/html/emoticons/smilie_pokal.gif) After seeing Rick's "Alien" build, Felix's "Neo 914", and meeting "JLo", Andyrew, Sir Andy and other's rides.... I just gotta' get'er done! |
914GT |
Jun 20 2005, 07:57 PM
Senior Member Group: Members Posts: 1,100 Joined: 11-October 04 From: Tucson Member No.: 2,923 Region Association: Southwest Region |
A few suggestions ...
- With those headers make sure you'll be able to route your exhaust on the left side to clear your shifter bar. - Don't use the front and back rubber intake manifold gaskets and instead use a thick bead of Permatex on the rails. - Get a one-piece oil pan gasket, much better than the 4-piece sets. Worth the extra cost. - Use a double-roller timing set with a 3-keyway crank sprocket so you can advance the cam. With the cam I'm using I've found a 4 degree advance makes a big difference in performance. |
Lo-Fi Version | Time is now: 12th June 2024 - 07:39 PM |
