jim912928 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,485 Joined: 8-January 04 From: Granger, IN Member No.: 1,536 Region Association: Upper MidWest ![]() |
Well, I finally got around to taking some measurements. I did not take the mirrors off, but rather took measurements from 3 points on each door to the base of the rubber gasket. On this first picture...the key to the alignment is the yellow line...that line when looking at the car from the front should be vertical on both sides!
Also, for strength, you must use the 911 backing plate. I riveted mine on after having the holes cut in. Drivers side: Attached image(s) ![]() |
ThinAir |
Best friends ![]() ![]() ![]() ![]() Group: Members Posts: 2,543 Joined: 4-February 03 From: Flagstaff, AZ Member No.: 231 Region Association: Southwest Region ![]() ![]() |
It would be really great if someone who has done this would be willing to trace their doors so that we'd have a same-size template of exactly where the holes are in relationship to the front curve of the door and the window guide as well as the size of the holes. I realize that some have mounted them further forward than others, particularly on the passenger side, but it would still be a very helpful guide that could be adjusted for front-to-back preference. Since the later "round style" 911 mirrors use the same holes, this would help a lot of club members who are interested in mirror upgrades.
P.S. - does anyone have the part numbers or some other way to know if you have 911 or 944 mirrors? This post has been edited by ThinAir914: Jun 22 2005, 10:18 PM |
Lo-Fi Version | Time is now: 17th June 2024 - 05:37 AM |
