> OH SHIFT... hard to get 4th & 5th, Rev & 1st grind a little also
GaroldShaffer
post Jun 23 2005, 08:30 PM
You bought another 914?
Well it was bound to happen, after two years of trouble free 914 fun I am am having problems shifting.
Problems:
1) Having trouble with reverse, sometime grinds when going into.
2) No problem with first while rollling (at a stop sign and such) but to stop and try to put into first it grinds a little.
New problem today....
3) Very hard to get into and out of 4th & 5th
I hope it just needs the shifter adjusted, maybe new bushings (IMG:http://www.914world.com/bbs2/html/emoticons/confused24.gif) I won't have time to look at it more until next week. Any other obvious things to check?
brp914
post Jun 23 2005, 08:44 PM
Unregistered
I was having trouble getting 4th. There are 2 bushings on the shift rod joint as it comes out of the fire wall. Problem solved.
Reverse may be a clutch not completely disengaging, but a pilot bearing is another possibility. Be careful about this - if a pilot bearing goes bad - and its a cheap little pos - it will take the input shaft of your tranny along with it.
itsa914   OH SHIFT... hard to get 4th & 5th   Jun 23 2005, 08:30 PM
SirAndy   <...   Jun 23 2005, 08:41 PM
brp914   I was having trouble getting 4th. There are 2 bus...   Jun 23 2005, 08:44 PM
ArtechnikA   other possibilities: engine mounts; transmission ...   Jun 24 2005, 12:12 AM
Pnambic   Hey Garold, If you end up having to take yours out...   Jun 24 2005, 06:46 AM
ClayPerrine   If you are having problems when the car is sitting...   Jun 24 2005, 07:32 AM
jfort   let me jump into this thread since i am having a s...   Jun 24 2005, 08:17 AM
Dave_Darling   <...   Jun 24 2005, 01:56 PM
- Lo-Fi Version Time is now: 15th July 2025 - 11:34 AM
