GaroldShaffer |
You bought another 914? ![]() ![]() ![]() ![]() ![]() Group: Benefactors Posts: 7,629 Joined: 27-June 03 From: Portage, IN Member No.: 865 Region Association: None ![]() ![]() ![]() |
Well it was bound to happen, after two years of trouble free 914 fun I am am having problems shifting.
Problems: 1) Having trouble with reverse, sometime grinds when going into. 2) No problem with first while rollling (at a stop sign and such) but to stop and try to put into first it grinds a little. New problem today.... 3) Very hard to get into and out of 4th & 5th I hope it just needs the shifter adjusted, maybe new bushings (IMG:http://www.914world.com/bbs2/html/emoticons/confused24.gif) I won't have time to look at it more until next week. Any other obvious things to check? |
ClayPerrine |
Life's been good to me so far..... ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 16,445 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille ![]() ![]() |
If you are having problems when the car is sitting still ,but not when it's moving then Check the Clutch Adjustment
If the clutch is not disengaging, then you will get problems like these. Also check the clutch tube. |
Lo-Fi Version | Time is now: 15th July 2025 - 10:31 AM |
