seal for shift fork, $#(*^ PINS |
tat2dphreak |
Jun 24 2005, 11:30 AM
stoya, stoya, stoya Group: Benefactors Posts: 8,797 Joined: 6-June 03 From: Wylie, TX Member No.: 792 Region Association: Southwest Region |
is ther a good way to get the pins out of the shift fork to replace the seal? my side-shifter leaks there a bit... and I have the seal, but it looks like it will take a press to get them out, and they will be messed up afterwards... are new pins available?
ClayPerrine |
Jun 24 2005, 11:41 AM
Life's been good to me so far..... Group: Admin Posts: 15,498 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille |
New pins are NOT available. Whatever you do, don't remove the pin on the inside of the trans. Remove the one on the outside.
I know this from experience. The pin can get damaged in removal, and you can end up in the hills around Austin stuck in third gear because the pin sheared. (IMG:http://www.914world.com/bbs2/html/emoticons/mad.gif) If you disassemble the outside one, you can replace it without draining the trans. If you disassemble the inside one, you have to drain the transmission and replace the shift console with the transmission hot!!! (BTW.. it is REALLY embarassing to have to get your 914 friends to push your car so you can get moving in 3rd gear.... BTDT!!!) |
Lo-Fi Version | Time is now: 31st May 2024 - 06:09 PM |
