Reinforced trailing arms |
echocanyons |
Jul 18 2003, 03:39 PM
Advanced Member Group: Benefactors Posts: 2,094 Joined: 24-December 02 From: Bay Area, CA Member No.: 7 Region Association: Central California |
What is the purpose of doing this? I have seen it on a couple of 6's but the only thing I can think of that it does is restricts lateral movement.
If this is a uselful suspension upgrade is it basically fab your own or is somebody producing these? |
Mueller |
Jul 18 2003, 04:26 PM
Paul,
I can save you almost 1 pound off each side of the rear needle bearing kit if you are willing to do a little spot welding. The 1.5dia tube can be cut down (currently it's ~12" long) so that only about 2" of material is pressed into the trailing arm on each end, this smaller section of tube should be spot/rosette welded into place once set up the correct distance into the arm. |
Lo-Fi Version | Time is now: 6th June 2024 - 10:25 AM |
