URY914 |
I built the lightest 914 in the history of mankind. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 127,329 Joined: 3-February 03 From: Jacksonville, FL Member No.: 222 Region Association: None ![]() |
I can't get the big 30mm nut off the outside end of the half-shalf.
I've hit it with my impact wrench for several minutes and it won't move. Than put a big breaker bar on it and I bent the bar. (Yes, I removed the cotter pin:wacko:) It's just rusted on. So is there a way to remove the c/v joint from the "inside" of the trailing arm? Also the small counter sunk screws that hold the disc on won't come out, but I'll just drill them out. Thanks Paul |
sj914 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 805 Joined: 20-August 03 From: San Jose, CA Member No.: 1,053 ![]() |
I've managed to unscrew the cv bolts, but it is a PITA. You have to get one of those long reach cv tools. The other hard part is separating the cv from the stub axle. I pulled and pried on the cv using the shaft to get it out.
Lo-Fi Version | Time is now: 4th July 2025 - 08:59 PM |
