| Allan |
Jun 28 2005, 05:12 PM
Teenerless Weenie ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,373 Joined: 5-July 04 From: Western Mesopotamia Member No.: 2,304 Region Association: Southern California |
Did a search but didn't find much. I'm looking for good, clear, step by step instructions on installing one. Car has no center console if that matters...........
| Mark Henry |
Jun 28 2005, 08:38 PM
that's what I do! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,065 Joined: 27-December 02 From: Port Hope, Ontario Member No.: 26 Region Association: Canada |
A lot of the VDO senders came from the factory with the wiring backwards on the gauge...so if yours doesn't work swap the wires.
I found that you must cut a grove beside most sparkplug holes to clear the sender ring even with the bend in it. Always use it under a plug...won't read true anywhere else. |
Headrage Cylinder Head Temp Gauge Jun 28 2005, 05:12 PM
Mueller you could be the 1st to document it Jun 28 2005, 06:55 PM
bd1308 i think it's just not in the same key with my ... Jun 28 2005, 06:59 PM
Britain Smith For my Electromotive set-up, I was just going to u... Jun 28 2005, 07:07 PM
Mueller ... Jun 28 2005, 07:47 PM
bd1308 ... Jun 28 2005, 07:49 PM
Headrage Jun 28 2005, 07:52 PM
bd1308 you cant use the center console wiring to wire you... Jun 28 2005, 07:55 PM
Headrage Jun 28 2005, 07:59 PM
bd1308 ... Jun 28 2005, 08:06 PM
SLITS Allan....as I remember, the first part of the wire... Jun 28 2005, 08:54 PM
type47 use the VDO wiring harness that goes with the gaug... Jun 28 2005, 09:37 PM
lapuwali There are two wires and you must run both of them ... Jun 28 2005, 10:09 PM
Britain Smith How come the stock CHT sender is 1 wire? Does thi... Jun 29 2005, 02:24 PM
tat2dphreak Aug 3 2005, 12:29 PM
JmuRiz OK, I'll look into a new sender...I thought th... Aug 3 2005, 03:29 PM![]() ![]() |
Lo-Fi Version | Time is now: 14th March 2026 - 01:25 PM |
