| Allan |
Jun 28 2005, 05:12 PM
Teenerless Weenie ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,373 Joined: 5-July 04 From: Western Mesopotamia Member No.: 2,304 Region Association: Southern California |
Did a search but didn't find much. I'm looking for good, clear, step by step instructions on installing one. Car has no center console if that matters...........
| SLITS |
Jun 28 2005, 08:54 PM
"This Utah shit is HARSH!" ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Benefactors Posts: 13,602 Joined: 22-February 04 From: SoCal Mountains ... Member No.: 1,696 Region Association: None |
Allan....as I remember, the first part of the wire from the ring under the spark plug is a thermosister wire (don't cut it)and terminates in a spade terminal after 12" or so? It then becomes normal wire to the guage.
Feasibly, if you wanted to lose the oil temp guage, I would think you could use the green? wire that ties into the main engine compartment harness (one used for the oil temp sensor..exits the harness near the battery) and plug into the commensurate spade terminal normally used for the oil temp guage in the center console. Of course, I could be smokin' some of that "Death Star Gold" too! The one that I had (haven't reinstalled it yet) had the ring placed under the CHT (engine was carbed though). |
Headrage Cylinder Head Temp Gauge Jun 28 2005, 05:12 PM
Mueller you could be the 1st to document it Jun 28 2005, 06:55 PM
bd1308 i think it's just not in the same key with my ... Jun 28 2005, 06:59 PM
Britain Smith For my Electromotive set-up, I was just going to u... Jun 28 2005, 07:07 PM
Mueller ... Jun 28 2005, 07:47 PM
bd1308 ... Jun 28 2005, 07:49 PM
Headrage Jun 28 2005, 07:52 PM
bd1308 you cant use the center console wiring to wire you... Jun 28 2005, 07:55 PM
Headrage Jun 28 2005, 07:59 PM
bd1308 ... Jun 28 2005, 08:06 PM
Mark Henry A lot of the VDO senders came from the factory wit... Jun 28 2005, 08:38 PM
type47 use the VDO wiring harness that goes with the gaug... Jun 28 2005, 09:37 PM
lapuwali There are two wires and you must run both of them ... Jun 28 2005, 10:09 PM
Britain Smith How come the stock CHT sender is 1 wire? Does thi... Jun 29 2005, 02:24 PM
tat2dphreak Aug 3 2005, 12:29 PM
JmuRiz OK, I'll look into a new sender...I thought th... Aug 3 2005, 03:29 PM![]() ![]() |
Lo-Fi Version | Time is now: 14th March 2026 - 11:45 AM |
