| Allan |
Jun 28 2005, 05:12 PM
Teenerless Weenie ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,373 Joined: 5-July 04 From: Western Mesopotamia Member No.: 2,304 Region Association: Southern California |
Did a search but didn't find much. I'm looking for good, clear, step by step instructions on installing one. Car has no center console if that matters...........
| type47 |
Jun 28 2005, 09:37 PM
Viermeister ![]() ![]() ![]() ![]() Group: Members Posts: 4,254 Joined: 7-August 03 From: Vienna, VA Member No.: 994 Region Association: MidAtlantic Region |
use the VDO wiring harness that goes with the gauge. i think the length of the harness is important so don't cut the wires to make it shorter (it's something like 15' long). i suspect for accurate gauge reading, you have to have the full length of the harness to drop the right voltage for accurate measurement.
Headrage Cylinder Head Temp Gauge Jun 28 2005, 05:12 PM
Mueller you could be the 1st to document it Jun 28 2005, 06:55 PM
bd1308 i think it's just not in the same key with my ... Jun 28 2005, 06:59 PM
Britain Smith For my Electromotive set-up, I was just going to u... Jun 28 2005, 07:07 PM
Mueller ... Jun 28 2005, 07:47 PM
bd1308 ... Jun 28 2005, 07:49 PM
Headrage Jun 28 2005, 07:52 PM
bd1308 you cant use the center console wiring to wire you... Jun 28 2005, 07:55 PM
Headrage Jun 28 2005, 07:59 PM
bd1308 ... Jun 28 2005, 08:06 PM
Mark Henry A lot of the VDO senders came from the factory wit... Jun 28 2005, 08:38 PM
SLITS Allan....as I remember, the first part of the wire... Jun 28 2005, 08:54 PM
lapuwali There are two wires and you must run both of them ... Jun 28 2005, 10:09 PM
Britain Smith How come the stock CHT sender is 1 wire? Does thi... Jun 29 2005, 02:24 PM
tat2dphreak Aug 3 2005, 12:29 PM
JmuRiz OK, I'll look into a new sender...I thought th... Aug 3 2005, 03:29 PM![]() ![]() |
Lo-Fi Version | Time is now: 14th March 2026 - 11:44 AM |
