> My Dell is leaky and I can't make it stop, Please Help
cdmcse
post Jun 30 2005, 10:30 PM
I have Dellorto 40s on my car (1.8L). During my rustoration over the winter I went ahead and rebuilt them and re-jetted them. The driver side works perfectly, but the passenger side has what I am assuming to be a float problem.
When the gas flows to the carb it just gushes out both throats and I can't figure out why. I have had the carb apart 6 or 7 times now, but can't make it better. Here are the things I've done already...
1)Tried every combination of old and new needle and seat. (The carbs never had this problem prior to the re-build)
2) Adjusted the float - I can blow in the inlet and with light pressure on the float it seems to stop ok.
3) Checked all the gaskets / seals
4) Tested the float, it floats like a cork
5) Ran my fuel pressure down to 1psi (normally it is a 4psi)
6) Inspected everything and saw no debris or dirt anywhere. (they were cleaned in a parts washer during the re-build)
7) Once it is assembled I can hear the float moving freely in the body.
Any other suggestions. What could it be? I'm stumped.
Type 4 Unleashed
post Jul 1 2005, 01:15 AM
CREATIVE TYPE lV ENGINEERING
Group: Retired Members
Mr. Stumped
It sounds like the float is droping to low, and the needle is binding up, not allowing the float to rise to cut off the fuel.
With the top plat off, let the float hang down, you see where the tab sits against the stand, raise the float and bend the tab so the float doesn't drop so low, it won't change where the float closes the needle and seat.
Hope this helps. (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif)
- Lo-Fi Version Time is now: 1st August 2025 - 05:21 AM
