| tat2dphreak |
Jul 1 2005, 10:48 AM
stoya, stoya, stoya ![]() ![]() ![]() ![]() ![]() Group: Benefactors Posts: 8,797 Joined: 6-June 03 From: Wylie, TX Member No.: 792 Region Association: Southwest Region |
any tricks to replacing the rear shocks? anything I should watch for?
I'm pulling the KYBs and putting on Bils this weekend... are pre-loaded springs better than the shorter ones? |
| MarkG |
Jul 1 2005, 10:53 AM
Member ![]() ![]() Group: Members Posts: 314 Joined: 24-May 04 From: Colorado Springs Member No.: 2,102 |
A fairly easy job, need a spring compressor. My Bilsteins had 5 slots to adjust the height. I put mine on 3rd slot from the bottom, which was very low. Shop that did my alignment moved it up 1 notch.
The lower bolts are a bit tricky if you have a sway bar, but job should take a couple hours. |
tat2dphreak rear shocks Jul 1 2005, 10:48 AM
URY914 Don't just remove that nut off the top of the ... Jul 1 2005, 10:58 AM
tat2dphreak cool, I looked it over, looked easy, I have a comp... Jul 1 2005, 10:58 AM
tat2dphreak Jul 1 2005, 10:59 AM
echocanyons Feeding the bolt through the trailing arm can be t... Jul 1 2005, 11:09 AM
! Use a jack under the arms to lift and then feed th... Jul 1 2005, 11:27 AM
Andyrew Jack up the back, put a jackstand under the traili... Jul 1 2005, 11:58 AM
spare time toys ... Jul 1 2005, 12:16 PM
qa1142 Took me ~1 hr to change my OEM's today to same... Jul 1 2005, 12:39 PM
tat2dphreak <... Jul 2 2005, 02:10 PM
! Shheeesh....I used a crescenthammer.... <... Jul 2 2005, 05:27 PM![]() ![]() |
Lo-Fi Version | Time is now: 7th December 2025 - 06:29 PM |
