| dougcoup |
Jul 1 2005, 05:16 PM
Member ![]() ![]() Group: Members Posts: 131 Joined: 5-March 05 From: mundelien, il Member No.: 3,715 |
Could someone point me in the direction of what to do to set up the lingage for the shifter correctly on a 901 sideshifter.
I have done 911 / 915's before but can not seem to get his one. I put in Welt, short shift kit and and I know prior to buying the car the shop had installed new clutch. The problem has plegged me since. I shift coupling just under shifter over and I get R and 1, but no 4/5, then I get 4/5 but no 1st/R. Is there an adjustment at the second lingage tube, or at the trans coupling? Dougcoup711@yahoo.com (IMG:http://www.914world.com/bbs2/html/emoticons/spank.gif) |
| ArtechnikA |
Jul 1 2005, 06:19 PM
rich herzog ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,390 Joined: 4-April 03 From: Salted Roads, PA Member No.: 513 Region Association: None |
in tailshifters (and maybe sideshifters too, but i've never worked with one...) there's a cone screw in the linkage at the coupler - just forward of the firewall under the adjustment access cover between the seats. if that cone screw gets loose, it will adversely affect your ability to get into different gear pair planes. (you didn't mention your car's year nor transmission type..)
be careful - they can rust in place (or been loctited by PO's trying too hard to fix a loose screw) and be quite hard to replace. they're inhex (Allen...) screws and the head will strip if you give it half a chance. if it's -very- loose, get it snug, but it would probably be good to have a spare. order one at the same time you get all the plastic bushings - they're not expensive... in tailshifters, there's a bushing way at the back that requires you to remove a roll pin to remove the selector finger. that job tends to get deferred because it's sometimes a PITA, but i've done it between DE practice sessions, so it doesn't have to be horrible. |
dougcoup 901 shifter lingage missing 4&5th Jul 1 2005, 05:16 PM
ematulac Have you replaced all of the shift bushings in the... Jul 1 2005, 05:21 PM
SGB Amazingly, thats all there is to work with. There... Jul 1 2005, 05:31 PM
! Besides, the pinch under the shifter and the bushi... Jul 1 2005, 06:53 PM
xsboost90 get the car into second/third. Put it up in third ... Jul 1 2005, 09:10 PM
BRAVE_HELIOS
get the car into second/third. Put it up in third... Feb 20 2011, 12:29 AM
Red-Beard Goto my home page.... Jul 2 2005, 07:25 AM
Dave_Darling If you just cannot adjust the shifter so you get a... Jul 2 2005, 07:19 PM
bd1308 (we need a excuse me with a tap smily...i'll s... Jul 3 2005, 07:05 AM
Dr Evil Look at the link in my signature to the 31 pages o... Feb 20 2011, 07:11 AM
gms
Could someone point me in the direction of what t... Feb 20 2011, 03:17 PM
Dr Evil You would be hard pressed to find more experienced... Feb 20 2011, 03:38 PM
BRAVE_HELIOS
You would be hard pressed to find more experience... Feb 20 2011, 05:05 PM
gms
You would be hard pressed to find more experienc... Feb 20 2011, 05:09 PM
Dr Evil :rotfl: Feb 20 2011, 07:33 PM![]() ![]() |
Lo-Fi Version | Time is now: 15th October 2026 - 04:06 PM |
