> Anti-roll bar Help!, Smart Racing anti-roll bar
Rog914
post Jul 2 2005, 05:43 PM
914 Fanatic
Getting ready to install a Smart Racing anti-roll bar(front). But not exactly sure how to install. Do i center the bearing mount to the "cresent" or should it be a little higher or lower? Plus the backing ring will not fit unless you cut some sheet metal from the inside where the gas tank was.
Has anybody else installed one of these anti-roll bars?
Any info will be a great help,
Thanks, Ralph
74 2.0
Trekkor
post Jul 2 2005, 06:33 PM
I do things...
Also take note of this: Like you said.
You must relieve the area inside of the inner fender well under the fuel tank.
I just pushed it aside with my air chisel. ( don't look if you are offended ) (IMG:http://www.914world.com/bbs2/html/emoticons/wink.gif)
Also, when you slide the bar through the fender well bearings for the first time and the bar binds up a bit.
Pull the bar out towards one side or the other and leaving it still inserted through the one side, use the bar as a lever to slightly tweak the fender well until the bearings are alligned. Only takes a moment or two.
Have fun...
Six hour job. Use spray lithium grease, too.
KT
Oh yeah, one more thing. Make sure the kit you have has two spacers for each side as this kit, which works on the 914, is designed for the narrower 911.
Rog914   Anti-roll bar Help!   Jul 2 2005, 05:43 PM
trekkor   I'm your guy! http://www.91...   Jul 2 2005, 06:10 PM
trekkor   Here:Install thread What size bar are you install...   Jul 2 2005, 06:17 PM
trekkor   Also take note of this: Like you said. You must re...   Jul 2 2005, 06:33 PM
trekkor   Hi! Me again http://www.9...   Jul 2 2005, 06:38 PM
KenH   Trekkor, Looks like you should put in Turbo-tie r...   Jul 2 2005, 08:18 PM
Rog914   Thanks Trekkor for the info & pics. I'm insta...   Jul 2 2005, 08:25 PM
trekkor     Jul 2 2005, 11:17 PM
- Lo-Fi Version Time is now: 3rd March 2026 - 07:38 PM
