> 901 shifter lingage missing 4&5th, help needed lingage set up
dougcoup
post Jul 1 2005, 05:16 PM
Could someone point me in the direction of what to do to set up the lingage for the shifter correctly on a 901 sideshifter.
I have done 911 / 915's before but can not seem to get his one.
I put in Welt, short shift kit and and I know prior to buying the car the shop had installed new clutch. The problem has plegged me since.
I shift coupling just under shifter over and I get R and 1, but no 4/5, then I get 4/5 but no 1st/R.
Is there an adjustment at the second lingage tube, or at the trans coupling?
Dougcoup711@yahoo.com (IMG:http://www.914world.com/bbs2/html/emoticons/spank.gif)
Dave_Darling
post Jul 2 2005, 07:19 PM
914 Idiot
If you just cannot adjust the shifter so you get all six gears, you should pull the carpeting over the center tunnel and look in there with a flashlight and a mirror or two. Check to see if the clutch cable tube is moving when you push the pedal; if so it has broken loose from the inside of the tunnel and can interfere with the movement of the bottom of the gear shift lever.
--DD
- Lo-Fi Version Time is now: 15th October 2026 - 04:06 PM
