Metal particles in strainer, Is this bad??? |
Allan |
Jul 1 2005, 08:54 PM
Teenerless Weenie Group: Members Posts: 8,373 Joined: 5-July 04 From: Western Mesopotamia Member No.: 2,304 Region Association: Southern California |
I am in the process of changing my oil and adjusting the valves and when I pulled out the strainer I found little pieces of metal shavings. I never saw these the first time I changed the oil after cam break in. Motor has about 500 miles on it.
dmenche914 |
Jul 3 2005, 05:29 PM
Senior Member Group: Members Posts: 1,212 Joined: 27-February 03 From: California Member No.: 366 |
You running a German oil filter? better not be an orange FRAM, frams are so junky, they will dump crap into your engine. I have had two FRAMs fall apart in use. Make sure you have a Mahle, or Mann oil filter, check you oil again soon, see if there is less metal next time (yippie!!!) also have an oil pressure gage, it is very important, and can tell you is bearings or pump is failing.'
good luck, maybe just break in crap i hope. |
Lo-Fi Version | Time is now: 7th June 2024 - 10:27 AM |
