> Is it Knocking or Not???, could be a rod... maybe something else??
Bruce Allert
post Jul 3 2005, 03:54 PM
Hellions asleep
I'd like to know what to look for when I take the 2.0 apart that was in Punkin. Since I've not gone into surgery of this kind I'm at a loss as to what I will see if it is a rod that was knocking.
When the engine was running a couple of us listened to it and proceeded to take a spark plug wire off one cylinder at a time to try to determine which one it was. We thought if the wire for the cylinder with the know was taken off it would cease to knock or quiet down which neither happened. Is this a way to find if it is a rod or which one it is???
.........b
redshift
post Jul 3 2005, 07:57 PM
Bless the Hell out of you!
G'luck Broose, hope it's something silly.. (IMG:http://www.914world.com/bbs2/html/emoticons/beerchug.gif)
M
Bruce Allert   Is it Knocking or Not???   Jul 3 2005, 03:54 PM
!   Rod knocks or other noises can be from crank beari...   Jul 3 2005, 03:59 PM
Rand   Do you hear it most when accelerating or cruising?...   Jul 3 2005, 04:10 PM
ejm   Are you sure it's a rod that knocking? Have yo...   Jul 3 2005, 05:25 PM
Bruce Allert     Jul 3 2005, 05:41 PM
TimT   this rod had to much knock http...   Jul 3 2005, 06:01 PM
TimT   anyhow, small end knock= tap tap tap big end knoc...   Jul 3 2005, 06:06 PM
Bruce Allert   Very interesting Tim. I just got thru with a high ...   Jul 3 2005, 06:12 PM
Porsche Rescue   Bruce, drain the oil and then pull the sump plate ...   Jul 3 2005, 06:18 PM
Bruce Allert   Jim, engine is out already http://...   Jul 3 2005, 06:27 PM
- Lo-Fi Version Time is now: 25th September 2026 - 02:05 AM
