DNHunt |
914 Wizard? No way. I got too much to learn. ![]() ![]() ![]() ![]() Group: Members Posts: 4,099 Joined: 21-April 03 From: Gig Harbor, WA Member No.: 598 ![]() |
Wife and kids are back in Michigan and I stayed here to work. I needed something to keep me busy so, I decided it was time to make up a new FI harness since me being a tinkerer mine was all cut up and spliced. This was for my MS. So I found a really great 60 pin plug and socket off of a mid 90's Mopar and I start to work on it Tuesday night. Damn, it was slow going.
Sat I was supposed to go to the Sovern races with Kevin. I had to call Kevin and say the car wasn't ready. No races. Sunday Kevin and I were driving to Portland to AX. Car's not ready. No go. Here's the problem. I need switched 12 volt to supply the main relay on the MS. I was using the black wire to the coil from pin 7 on the 12 pin plug off the relay board before so I hook it up like that on Saturday. It keeps running when I turn the key off WTF. When it's running on after I turn it off it has 4 volts at the primary coil of the main relay. That 4 volts keeps the relay closed. If I touch the brakes the voltage drops and the relay opens. Where the hell is that 4 volts coming from. So, I rip everything out and check for shorts and bad connections. MS check out OK so, I start following wiring back through the relay board to the fuse box to the ignition switch and gauges. Everything looks OK but there is quite a bit of resistance. I still don't know what is back feeding that relay. I'm tired of screwing with it. I think I'll just put a zener in the line. THIS IS WORSE THAN PLUMBING. (IMG:http://www.914world.com/bbs2/html/emoticons/barf.gif) Dave |
scotty914 |
suby torque rules ![]() ![]() ![]() Group: Members Posts: 1,528 Joined: 20-July 03 From: maryland, the land of 25 year Member No.: 924 ![]() |
try a new relay ( on the relay board )the old one might be gunked up enough not to truely open, or use the pass front connector on the four pin it is switch by the main relay on the reg board.
Lo-Fi Version | Time is now: 1st August 2025 - 02:48 PM |
