DNHunt |
914 Wizard? No way. I got too much to learn. ![]() ![]() ![]() ![]() Group: Members Posts: 4,099 Joined: 21-April 03 From: Gig Harbor, WA Member No.: 598 ![]() |
Wife and kids are back in Michigan and I stayed here to work. I needed something to keep me busy so, I decided it was time to make up a new FI harness since me being a tinkerer mine was all cut up and spliced. This was for my MS. So I found a really great 60 pin plug and socket off of a mid 90's Mopar and I start to work on it Tuesday night. Damn, it was slow going.
Sat I was supposed to go to the Sovern races with Kevin. I had to call Kevin and say the car wasn't ready. No races. Sunday Kevin and I were driving to Portland to AX. Car's not ready. No go. Here's the problem. I need switched 12 volt to supply the main relay on the MS. I was using the black wire to the coil from pin 7 on the 12 pin plug off the relay board before so I hook it up like that on Saturday. It keeps running when I turn the key off WTF. When it's running on after I turn it off it has 4 volts at the primary coil of the main relay. That 4 volts keeps the relay closed. If I touch the brakes the voltage drops and the relay opens. Where the hell is that 4 volts coming from. So, I rip everything out and check for shorts and bad connections. MS check out OK so, I start following wiring back through the relay board to the fuse box to the ignition switch and gauges. Everything looks OK but there is quite a bit of resistance. I still don't know what is back feeding that relay. I'm tired of screwing with it. I think I'll just put a zener in the line. THIS IS WORSE THAN PLUMBING. (IMG:http://www.914world.com/bbs2/html/emoticons/barf.gif) Dave |
brp914 |
Unregistered ![]() |
good call Ed (IMG:http://www.914world.com/bbs2/html/emoticons/beerchug.gif)
Well, I guess not related afterall, but for purposes of commiseration: the fuse 9 circuit is really the "area 51" of 914dom. My -6 was occasionaly blowing #9. Found engine compartment light lead dangling disconnected. Fixed. 2 weeks later #9 blows again. Must be fluke - put in new fuse. 2 weeks later #9 blows. Weird - when stepping on brakes gas gauge goes to zero and alt light brite. Real problem - groan. Methodically search: put in new fuse. step on brakes - no prob. Turn on fogs - no prob. Turn on park lights - no prob. Turn on headlights - no prob. turn sig left - no prob. turn sig right - POP! fuse blows - AHA!! Now this sould be simple. Check connections at frnt/rear lights - no prob. Trace circuit back. Gets bad - 914-6 wiring is part 914, part 911, part wtf?!? Whole lotta wires pile-on to emergency light switch then split of in a hundred directions. Guess I gotta merge into the fast lane and stay put (IMG:http://www.914world.com/bbs2/html/emoticons/beer.gif) |
Lo-Fi Version | Time is now: 1st August 2025 - 02:22 PM |
