Converting /4 ignition switch to /6 style???, A conversion not talked about!?!?! |
Mueller |
Jul 21 2003, 11:25 AM
I've known this has been done before, but I have never seen it documented or even really talked about.
Besides the /6 specific steering column cover, what other parts are /6 original parts? The dash, the switch itself or ????? Sorry, bored at work while waiting for Tech Support to help me out on the phone..... |
Qarl |
Jul 21 2003, 01:15 PM
Shriveled member Group: Benefactors Posts: 5,233 Joined: 8-February 03 From: Florida Member No.: 271 Region Association: None |
If you just wanted the dash-mounted ignition switch... Can you do this...
1. Remove the ignition switch and lock mechanism from the -4 column. 2. Mounted the a 911 or 914-6 switch (minus the column lock) to the left of the wheel (maybe in the third switch hole). 3. Wire/rig the ignition switch to the wiring harness. You'd have to come up with a new shroud to hide the old column-mounted ignition switch location... otherwise you'll have a funny-looking hole there. You'd lose your steering wheel lock mechanism. |
Lo-Fi Version | Time is now: 4th June 2024 - 04:46 AM |
