another day older.., and deeper in debt |
xsboost90 |
Jul 6 2005, 06:17 PM
Senior Member Group: Members Posts: 1,393 Joined: 2-August 04 From: cincinnati Member No.: 2,432 |
so after getting my distributor back together, installed and lined up correctly, i tried to fire her up. she fired instantly, then died. She will start, idle for a second then die again. Turn the key to ON and you could hear the pump prime then turn off. Crank it and it would start, choke, die. Checked and all the injectors are pulsing-with a noid light- and power to coil is good. The ignition box is flashing when you crank it so its reading correct. I pulled the relays from the board, switched them around and then tried it all again....now the pump does NOT prime, and still no start. I checked the haynes manual, it says check for 12v @ 86 and ground @ 85, but im not sure which relay is for the fuel pump, they dont say. Cant find it anywhere. I checked all of them, a couple of them have 12v and ground, the first and fourth ones i believe didnt. The light was alittle dim, put in another battery and light was much better, still no prime to pump now. Tried switching on the ignition w/ the test light on the fuel pump + terminal and no power. Ran a jumper to the pump from a spare battery and it runs fine. Am i looking at a bad ignition switch? Anyone? (IMG:http://www.914world.com/bbs2/html/emoticons/pray.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/confused24.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/chair.gif)
joeav8tor |
Jul 6 2005, 06:29 PM
Member Group: Members Posts: 408 Joined: 23-January 05 From: mattituck, Long Island NY Member No.: 3,493 |
I just tuned my motor up (after removing it) got it back in the car...put the distributer back in, lined it up...sarted the car...and it did the same thing your car seems to be doing...got out the timing light (3500 rpm) and now the car is running nicely...just a hair off with the timing and the car ran like crap. the timing might be off. (IMG:http://www.914world.com/bbs2/html/emoticons/idea.gif)
Joe |
Lo-Fi Version | Time is now: 3rd June 2024 - 12:23 AM |
