Upgrading 1.8 to 2.0 Euro Spec, Pistons and Cylinders |
Nor.Cal.914 |
Jul 11 2005, 02:14 PM
1975 914 3.0SC Group: Members Posts: 1,050 Joined: 28-January 05 From: Weatherford, TX Member No.: 3,523 Region Association: None |
I have a '75 1.8 and I would like to know if it is possible and what would be required to convert to a 2.0 Euro Spec. Is there block and/or head machining necessary? If not possible, what is the biggest cylinders I could put on my 1.8? Let me know. Thanks
-Chris |
tat2dphreak |
Jul 11 2005, 02:17 PM
stoya, stoya, stoya Group: Benefactors Posts: 8,797 Joined: 6-June 03 From: Wylie, TX Member No.: 792 Region Association: Southwest Region |
I'm 99% sure the 'euro spec' is the same as the 2.0 US spec from 73-74 with FLAT TOP pistons... no case machining needed, until you get to about 100mm pistons you won't have to flycut the head until about 103mm pistons. I'm NOT sure about what the 'euro' heads valve sizes were... but I think they were the same. |
Lo-Fi Version | Time is now: 31st May 2024 - 08:33 PM |
