Cracked ignition switch replaced, still no start, What else could be wrong? |
rd914 |
Jul 12 2005, 12:15 PM
Newbie Group: Members Posts: 31 Joined: 13-April 05 From: San Diego, CA Member No.: 3,928 |
Screwdriver trick at solenoid starts the car so I replaced ignition switch but it did not fix the problem. Not even a click when I turned the key but all the lights and fuel pump come on. The seat belt buzzer box under passenger
seat has been disconnected and the yellow wires connected to bypass it per recommendation from previous posts. Suggestions? Thanks. |
Mueller |
Jul 12 2005, 12:32 PM
do you get 12vdc at the yellow wire when you turn the key??
Lo-Fi Version | Time is now: 8th June 2024 - 07:46 PM |
