Cracked ignition switch replaced, still no start, What else could be wrong? |
rd914 |
Jul 12 2005, 12:15 PM
Newbie Group: Members Posts: 31 Joined: 13-April 05 From: San Diego, CA Member No.: 3,928 |
Screwdriver trick at solenoid starts the car so I replaced ignition switch but it did not fix the problem. Not even a click when I turned the key but all the lights and fuel pump come on. The seat belt buzzer box under passenger
seat has been disconnected and the yellow wires connected to bypass it per recommendation from previous posts. Suggestions? Thanks. |
scruz914 |
Jul 12 2005, 07:28 PM
Senior Member Group: Members Posts: 815 Joined: 26-February 04 From: Santa Cruz, CA Member No.: 1,724 |
You may have voltage but not enough juice. Make sure the contacts (male and female) are clean and tight. You can split the male pin with a razor blade which will help tighten the connection. Also make sure the connections on the starter are clean and tight. -Jeff |
Lo-Fi Version | Time is now: 8th June 2024 - 01:05 PM |
