grasshopper |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,613 Joined: 10-December 04 From: Valdosta, GA Member No.: 3,258 Region Association: None ![]() |
ok, first question. i know there is a black wire, red wire and yellow wire that go to the starter. the black go to the battery-correct? yellow to the switch-corret? and red...where do that wire go?? second question. how do i remove the black ring that goes around the guages and is right on top of the glass...do they screw off?? and last question. what is this mirror and is it worth anything?? Thanks
Attached image(s) ![]() |
ArtechnikA |
rich herzog ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,390 Joined: 4-April 03 From: Salted Roads, PA Member No.: 513 Region Association: None ![]() |
i just don't know how it's done in a /4. in SOME cars, the +post on the starter terminal is used as the connection from the alternator. that's how it works on my 911, where the alternator is at the back, the starter is in the middle, and the batteries are in the front. so look to see if that's possible - if it goes to (comes from) the alternator. be very careful - you are dealing with huge amp sources, none of this stuff is fused, and crossed connections can be expensive at best, downright hazardous at worst. maybe if we keep bumping this topic to the top, someone who KNOWS /4 electrics will be able to help you. |
Lo-Fi Version | Time is now: 11th July 2025 - 06:32 AM |
