> Hey Rick check out the new trans tool
spare time toys
post Jul 16 2005, 12:14 PM
hooked on grilling food.
Remember when we cut it down it had some high and low spots. I tried to do the sandind down with a chunk of T angle that was 3" wide and 1" thick. I kept getting a low spot I could not work out. (IMG:http://www.914world.com/bbs2/html/emoticons/mad.gif) Before I trashed it and took too much off I stopped. I figured I needed a flat plate to sand it on. We had a bunch of these 1/4 inch plates we were tossing out at work and I got to thinking (IMG:http://www.914world.com/bbs2/html/emoticons/idea.gif) I used a counter bore about 3/4 dia, and put a hole in the center. Cam wanted in on the action so I figured he could hold the drill as well as I can (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif) It took a little while bu he got it done. We did a quick test fit on the input shaft to be sure it had some space so it didnt screw up the shaft.
spare time toys
post Jul 16 2005, 12:20 PM
We then cleaned it up and put some sanding discs on it and stood the trans on end with the input shaft in the new hole. We spun it a couple of times and checked. it took about 30 spins and the trans fits on the adapt, plate with no gaps. (IMG:http://www.914world.com/bbs2/html/emoticons/smilie_pokal.gif) If you ever cut another one let me know and Ill send it up to you. I would think it may be a good thing to use on a regular trans to make sure the front face is true. I am not sure how they mount though.
- Lo-Fi Version Time is now: 1st August 2025 - 04:51 PM
