> S.S. Fuel Line Replacement by Clay ?????, My math may be screwed up here
914forme
post Jul 15 2005, 04:28 PM
I have been reading and gathering the items to replace my plastic lines with SS, my plastics are real bad.
So I read Clay's nice documentation on how to do this. I get me some nice pieces of SS tubing today, come home. Look at my stuff and go DOAH!
Clay calls for 7/16" line for the main pressure loop and return loop. So I am wondering if the number got messed up.
I grab my calipers and start measuring
Fuel log, pump, and pressure regulators = .3271 okay this is about 8-mm makes good sense now.
3/8" line = .3750
7/16" line = .4375
So it looks to me I should have bought a few sticks of 5/16" line which is .3125 or 21/64s (yeah right) which is .2813
Or am I just smoking crack here (IMG:http://www.914world.com/bbs2/html/emoticons/screwy.gif) and this will work?
Or maybe all 3/8" line and make the hose stretch just a little.
(IMG:http://www.914world.com/bbs2/html/emoticons/headbang.gif)
(IMG:http://www.914world.com/bbs2/html/emoticons/welder.gif) and braze new ends onto the lines and build me some new fuel logs
Just wondering Clay is a great guy just thinkin I may be nuts.
Stephen
ClayPerrine
post Jul 16 2005, 03:38 PM
There are 2 sizes of fuel lines coming off the bottom of a 914 fuel tank. When I did the SS line install, I chose to use the larger of the lines all the way through the system. This was based on the fact that I am using MFI on my /6. I was told that it uses more fuel, so I wanted to make sure there was no restriction there. If you are using the stock D-Jet or L-Jet, you can use the smaller line.
If you use the trick of threading the outside of the lines with a die, you don't need to double clamp them. Even without a clamp I can't pull the rubber hose off.
I got the lines through a local 914 racer. I don't know the place he bought them, sorry.
Cap'n.... The reason I recommend replacing the lines is that I have personally lived thorugh a 914 fire. That fire was in my wife's 914, and it took me 6 years to get the car back on the road. It also almost cost me my marriage.
Steel lines are cheap insurance.
914forme   S.S. Fuel Line Replacement by Clay ?????   Jul 15 2005, 04:28 PM
Demick   Here's what I would use: If your fuel pump is...   Jul 15 2005, 04:45 PM
Demick   And like you pointed out, 5/16" is the easiest to ...   Jul 15 2005, 04:48 PM
914forme   Demick Thanks for the great advice. Stephen   Jul 15 2005, 04:49 PM
smooth_eddy   I can see the advantages of using SS fuel lines th...   Jul 15 2005, 05:21 PM
Mueller   <...   Jul 15 2005, 05:32 PM
Lou W     Jul 15 2005, 05:35 PM
JOHNMAN
  Jul 15 2005, 05:46 PM
kwales   I sent him to a truck hose repair shop. Trucks h...   Jul 15 2005, 06:49 PM
"7"     Jul 15 2005, 07:58 PM
tod914   The OEM plastic line is available, but it was like...   Jul 15 2005, 10:14 PM
MecGen   Hey Modern day fuel lines are a perfect upgrade f...   Jul 16 2005, 01:37 AM
914forme   SS line is easy to pickup local you just have to s...   Jul 16 2005, 08:04 AM
scotty b   http://www.inlinetube.com/ These guys sell length...   Jul 16 2005, 08:12 AM
Cap'n Krusty   I don't understand the percieved need to repla...   Jul 16 2005, 11:11 AM
tod914   Actually, my lines inside the tunnel were good aft...   Jul 16 2005, 11:53 AM
ClayPerrine   There are 2 sizes of fuel lines coming off the bot...   Jul 16 2005, 03:38 PM
kwales   Yeppers, My lines became stainless after watching...   Jul 16 2005, 03:50 PM
zymurgist   Cheap insurance indeed. I'm not going through...   Jul 16 2005, 06:22 PM
smooth_eddy   Stephen... Just wondering.........are you going t...   Jul 16 2005, 06:37 PM
tat2dphreak   is this a good deal?! Summit "kit" I though...   Jul 18 2005, 02:03 PM
914forme   Nope the engine is out of the car right now, repai...   Jul 19 2005, 06:09 AM
tat2dphreak   so, anodizing is just for bling, so I ordered the ...   Jul 19 2005, 09:17 AM
- Lo-Fi Version Time is now: 2nd April 2026 - 07:22 PM
