BMartin914 |
||| ![]() ![]() ![]() Group: Members Posts: 1,408 Joined: 30-May 04 From: Oregon Member No.: 2,128 Region Association: Pacific Northwest ![]() |
I've got a '74 2.0 engine with d-jet that is running lean. Biggest indications are whitish plugs and high oil temps - about 240-250 after highway cruising in 90-95 degree weather (very little humidity). While moving oil is about 230-235, but when stopped or considerably slowed, temps rise to about 245-250. Cyl head temps will stay a consistent 300-325.
I have switched out 3 good MPSs. 2 049s and an 037. I cannot seem to find an 043, but thought that at least with the 037 I would see some difference in running condition. I have also switched out 2 TS2 sensors with no difference in plug color or oil temps. I plan on trying to retard my timing some, check fuel pressure and replace filter tonight. Possibly bump pressure up to 32-34 psi. Short of dyno'ing the car (which I cannot afford to do at the moment) does anyone have any suggestions for richening up the mixture? I am considering a pot on the TS2 sensor. But that would only be if nothing else works. Additionally, I do not seem to have a sock strainer in my tank. Where should this strainer be and is it possible to simply drop one in? Just noticed this late last night. TIA |
ArtechnikA |
rich herzog ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,390 Joined: 4-April 03 From: Salted Roads, PA Member No.: 513 Region Association: None ![]() |
has it always done this? if not, what happened right before it started?
what plugs are you running? they could be too hot if they're not the spec plugs. and your sure there are no obstructions to your oil cooler and that your flappers are working ? you have hugely hot oil temps but normal-cold CHT's. something is wrong with this picture... have you calibrated your oil temps with a deep-fry thermometer or an IR pyrometer? tank picture: |
Lo-Fi Version | Time is now: 2nd July 2025 - 10:50 PM |
