> Running Lean, Suggestions
BMartin914
post Jul 19 2005, 10:04 AM
I've got a '74 2.0 engine with d-jet that is running lean. Biggest indications are whitish plugs and high oil temps - about 240-250 after highway cruising in 90-95 degree weather (very little humidity). While moving oil is about 230-235, but when stopped or considerably slowed, temps rise to about 245-250. Cyl head temps will stay a consistent 300-325.
I have switched out 3 good MPSs. 2 049s and an 037. I cannot seem to find an 043, but thought that at least with the 037 I would see some difference in running condition. I have also switched out 2 TS2 sensors with no difference in plug color or oil temps. I plan on trying to retard my timing some, check fuel pressure and replace filter tonight. Possibly bump pressure up to 32-34 psi.
Short of dyno'ing the car (which I cannot afford to do at the moment) does anyone have any suggestions for richening up the mixture?
I am considering a pot on the TS2 sensor. But that would only be if nothing else works.
Additionally, I do not seem to have a sock strainer in my tank. Where should this strainer be and is it possible to simply drop one in? Just noticed this late last night.
TIA
BMartin914
post Jul 19 2005, 11:12 AM
I suspect that the car has been running lean for some time now. When I purchased it last year it would not pass emissions - PO had his mechanic re-time and adjust MPS. Leaned out car to pass.
I tuned the car about 9 mos ago with new Bosch plugs - standard for the engine (W7CC IIRC). I still have the old plugs and will check them when I get home, but I believ that they looked similar. They were not a nice tan color though, definitely lighter.
I changed the oil temp sender and gauge module with one from a 911. Purchsed a matched set from Automotion. I have not yet tested the gauge and sender, but it has been suggested. Shortly thereafter I installed a CHT gauge, so it hasn't been but a few months that I have been able to accurately monitor the engine and it has not been hot enough until recently to notice the problem.
All tin and flaps are in place and cooler *appears* clean but I plan on checking behind it once I get the car up on stands to do the filter.
BMartin914   Running Lean   Jul 19 2005, 10:04 AM
bd1308   same problem my engine had. the timsert fused itse...   Jul 19 2005, 10:07 AM
ArtechnikA   has it always done this? if not, what happened rig...   Jul 19 2005, 11:02 AM
ArtechnikA   cr&p - you can't edit-in an attachment after y...   Jul 19 2005, 11:03 AM
BMartin914   I suspect that the car has been running lean for s...   Jul 19 2005, 11:12 AM
ArtechnikA
- Lo-Fi Version Time is now: 2nd July 2025 - 11:16 PM
