> Engine build Take 2, The rebirth of my 2270
DNHunt
post Jul 15 2005, 07:10 AM
914 Wizard? No way. I got too much to learn.
All the parts are back except for the ones I forgot to order which I don't know about yet cause we haven't got that far yet. I'm sure I have enough to build 95% of the engine anyway. It's all new except for the heads, oil pump, and crank which was repolished.
Gotta take a first step. Ring gaps. Here's the top ring at a depth of 12 mm (top of piston to 2nd ring). .019". These are pregapped from JE. Everyone say run em at that gap. All rings were between .018" and .020"
Dave
root
post Jul 20 2005, 10:58 AM
Two Wheeled Type4 Completed!
Allright I was following along O.K. until you got to the type1 oil pump??
Why are you using a type 1 pump? (IMG:http://www.914world.com/bbs2/html/emoticons/wacko.gif)
By the way! This thread 'ROCKS!' (IMG:http://www.914world.com/bbs2/html/emoticons/aktion035.gif)
DNHunt   Engine build Take 2   Jul 15 2005, 07:10 AM
DNHunt   Time to move on to another task. Put the can gear ...   Jul 15 2005, 09:48 AM
Tom Perso   Dave, Are those your replated Nikkies, or new one...   Jul 15 2005, 09:50 AM
DNHunt   The gear will only align one way cause the spacing...   Jul 15 2005, 09:51 AM
DNHunt   This is correct. All the holes line up   Jul 15 2005, 09:52 AM
DNHunt   After chasing the bolt holes and cleaning I tighte...   Jul 15 2005, 09:54 AM
DNHunt   Tom They are reconditioned.   Jul 15 2005, 09:55 AM
DNHunt   On to the crankshaft. Time to install #3 main bear...   Jul 15 2005, 09:59 AM
Jake Raby   Lookin good Dave! Glad you are back on it- so...   Jul 15 2005, 10:04 AM
DNHunt   Here's the rest of that assembly. After the be...   Jul 15 2005, 10:51 AM
Jake Raby   Dave, a small cooking eye works well for the gears...   Jul 15 2005, 11:34 AM
Demick   Ha Ha Dave. When I did mine I didn't bother t...   Jul 15 2005, 12:00 PM
DNHunt   Actually, it wasn't any problem. Everything we...   Jul 15 2005, 02:00 PM
DNHunt   Cleaned everything and installed bearings   Jul 15 2005, 02:01 PM
Ferg   I was wondering what the outcome to your motor was...   Jul 15 2005, 02:02 PM
DNHunt   I checked the clearance with Plastigauge All 4 wer...   Jul 15 2005, 02:03 PM
DNHunt   ARP rod bolts torqued to 15 then 20, then 25 and f...   Jul 15 2005, 02:07 PM
DNHunt   Rod side clearance.019"   Jul 15 2005, 02:09 PM
crash914   Keep going Dave!! This one has engine reb...   Jul 15 2005, 02:15 PM
DNHunt   Cam Bearings and Main bearings #1, #2 and the thru...   Jul 15 2005, 08:11 PM
DNHunt   Thrust bearing have flanges which limit the moveme...   Jul 15 2005, 08:19 PM
DNHunt   Here are the dowels in the right side of the case....   Jul 15 2005, 08:22 PM
DNHunt   I set the thrust bearing in the case and centered ...   Jul 15 2005, 08:28 PM
DNHunt   Bearing #1 scribed.   Jul 15 2005, 08:29 PM
DNHunt   Bearings scribed   Jul 15 2005, 08:30 PM
DNHunt   Next I installed the cam and crank. I lined up the...   Jul 15 2005, 08:34 PM
DNHunt   Check of clearances. Tightest spot is rod cap to c...   Jul 15 2005, 08:35 PM
DNHunt   The last thing I did today was torque down the cas...   Jul 15 2005, 08:40 PM
brp914   Who made your counterweighted crank? Can you tell...   Jul 15 2005, 10:05 PM
Mueller   I'll be adding this to my "favorites".....I sh...   Jul 15 2005, 10:47 PM
michelko   <...   Jul 16 2005, 01:42 AM
Tom Perso   Heheheh.... I have some of the same pictures Dave...   Jul 16 2005, 06:40 AM
rhodyguy   dave's new video, titled "much faster the seco...   Jul 16 2005, 06:49 AM
DNHunt   The scribe procedure is straight out of Jake's...   Jul 16 2005, 07:07 AM
Tom Perso   It's supposed to be quicker the second time ar...   Jul 16 2005, 07:23 AM
Jake Raby   You should see the clearances inside the 3.0! ...   Jul 16 2005, 12:46 PM
9146986   I remember the thread on the engine running too ri...   Jul 16 2005, 07:02 PM
DNHunt   Perry Here's a link to the dead engineThread   Jul 16 2005, 07:07 PM
V6914     Jul 16 2005, 10:40 PM
9146986     Jul 17 2005, 07:44 AM
bd1308   http://www.914world.com/bbs2/html/e...   Jul 17 2005, 07:37 PM
ablose58   RIGHT ON DAVE http://www.914...   Jul 18 2005, 03:15 AM
rhodyguy   "Super 2 liter"? so what the hell is that? k   Jul 18 2005, 05:43 AM
Jake Raby   My attempt to attain 50 MPG from a 2017cc TIV.... ...   Jul 18 2005, 07:06 AM
rhodyguy   long stroke huh? still torquey down low? hit that ...   Jul 18 2005, 07:18 AM
DNHunt   Jake I figured that one out. I chased them with a...   Jul 18 2005, 07:42 AM
rhodyguy   are the 2 return tubes plugged on your heads dave?...   Jul 18 2005, 07:51 AM
Jake Raby   Kevin, Thats exactly why we are doing this Super 2...   Jul 18 2005, 08:03 AM
DNHunt   Kevin My heads are off a 73 so no ports. I have a ...   Jul 18 2005, 08:07 AM
rhodyguy   surprizing cr. it's been a while since i visit...   Jul 18 2005, 08:08 AM
Jake Raby   90.5 mm bore.. its a 78.4mm crank... I used a TI ...   Jul 18 2005, 08:30 AM
rhodyguy   save those good 1.7 cyl guys!!   Jul 19 2005, 11:50 PM
DNHunt   I didn't advance the cam at all. Looking at th...   Jul 20 2005, 07:17 AM
DNHunt   Oil pressure relief pistons. I test fit them and t...   Jul 20 2005, 07:24 AM
DNHunt   The large one goes on the right side front on the ...   Jul 20 2005, 07:56 AM
DNHunt   I found this old square from my dad and I used it ...   Jul 20 2005, 07:59 AM
DNHunt   The small one goes between the lifter bores on cyl...   Jul 20 2005, 08:00 AM
DNHunt   Here's a type 1 oil pump that's ready to g...   Jul 20 2005, 08:02 AM
DNHunt   Nice and clean and packed with a little grease   Jul 20 2005, 08:04 AM
root   Allright I was following along O.K. until you got ...   Jul 20 2005, 10:58 AM
groot   Dave, I think I topped your breaking the stud mov...   Jul 20 2005, 12:04 PM
Jake Raby   He is using a TI pump because it is far superior, ...   Jul 20 2005, 12:18 PM
DNHunt   Still making progress. Here's something that...   Jul 21 2005, 06:00 PM
DNHunt   Here's the other end of the Q-tip from the ins...   Jul 21 2005, 06:03 PM
DNHunt   Here's the windage tray and the oil pick up in...   Jul 21 2005, 06:09 PM
rdauenhauer   So you not going with a Tuna can or Deep sump?   Jul 21 2005, 06:11 PM
DNHunt   I'm trying to show that you have to catch a ri...   Jul 21 2005, 06:13 PM
DNHunt   Rich, No deep sump or tuna can. Here's the di...   Jul 21 2005, 06:19 PM
DNHunt   Here it is in the case half and nutted down. I hav...   Jul 21 2005, 06:24 PM
DNHunt   I already posted pics of the crank and cam aligned...   Jul 21 2005, 06:29 PM
Dead Air     Jul 21 2005, 07:29 PM
Dead Air   "I'm trying to show that you have to catch a r...   Jul 21 2005, 07:34 PM
DNHunt     Jul 23 2005, 08:35 AM
V6914   http://www.914world.com/bbs2/h...   Jul 23 2005, 07:37 PM
DNHunt   You guys are both right. A new washer and new bolt...   Jul 23 2005, 08:00 PM
- Lo-Fi Version Time is now: 2nd April 2026 - 05:46 PM
